EddieWalker
Epic Contributor
#6 "yup" for the Advantech :thumbsup:
It's funny how things sort of reverse, couldn't stand the old OSB when it started showing up on the jobs years ago being used to plywood. Todays plywood seems like wavy horrible junk now, esp for roof & wall sheathing.
No tongue and groove sub flooring that I'm aware of is going to give you 4x8 once slid together. That measurement is for the outer edge of the sheet including the tongue. Once you slide it together, it will be half an inch short, which adds up with every sheet.
Most floor joists are on 24 inch centers. Going with 19.2 inches will give you a lot more strength with minimal expense. But if it's a small cabin, 16 inches is even better. 19.2 is marked on every steel tape with a red diamond for framing.
As mentioned, Advantech is the best sub flooring out there. It's the same price as the plywood, which makes it a no brainer.
