3-4 Acre mowing solution
   / 3-4 Acre mowing solution #1
sbohan
Mims FL, it's by Cocoa Beach
L3700SU Kubota
OK, after successfully killing both the craftsman pro and mtd, I'm looking for a mowing solution for around the house and two corrals which is about 3-4 acres. they're bahia grass which grows well even in low water, but needs cutting about every 5 days in the summer. Considering....
GR2010 - 48" maybe a little slow and narrow? found a good deal. the diesel I can get a 54" but is like $2K more.
Z series - pretty fast and wider if you step up to the 227, but over $2K more though can finance 2 yrs longer so pymt is lower than 2010 but for two more years-LOL; but singular in purpose, just mows.
BX1860 - about $4k more can do more things, speed in the middle, can finance longer so pymt would be about the same monthly as the 2010; can add other items later - not sure on handling on a lawn around the house and fences though.
was told F series really too much for this application....
Thoughts? Advice? Hints?
Thanks in advance.
   / 3-4 Acre mowing solution #2
This is the same thing I went thru several yrs ago. The zero turn mowers will mow circles around any tractor. But like you say they are good for one thing. I have alot of small acerage, my rent house has 4 acres, my mothers is a acre, we mow 5 out of 16 acres at my residence, and 3 acres at my family cemetary. I went with a zg 20 in 2007. It has 400 hrs of trouble free service starting the mowing season this year. Just maintence and blades. So now I am looking at a bx25 for the tractor end. But I couldnt buy both at the same time.
   / 3-4 Acre mowing solution #3
If you went with the BX, get the 60 inch deck, you wont regret it. After hearing words likee corral- I'd say make sure you get the FEL as well. You wil lwonder how you ever lived without. You will find more uses for the tractor then you ever realized.
   / 3-4 Acre mowing solution #4
Nothing like a Z for mowing, but do you have other uses? If you do, that BX will be well worth it for you. I mowed a 2.5 acre property and a 3 acre property for 8 years with a BX, and it was a fine machine. I bought a Z in 2008, and a B2620 in 2009, so I have the best of both worlds-but if could only have one machine, it would be a BX!
Will
   / 3-4 Acre mowing solution #5
I cut a couple of acres with a BX23....Takes around an hour with a 54" mower.
As others have said, an FEL is the best part of the BX...If you currently use a dumpcart or wheelbarrow, you'll wonder what and why you did this if you go with a BX with FEL....
I'd love to have a Z but I have too many things with engines now. Don't want to add another just to cut grass, and that's all you can do with a Z.
Shop around and get what is most suitable for your needs. Good luck.
Guess i should note. I have a L3700 with FEL, and BH, I don't wanna use it around the house as the hog is too rough a cut and don't wana driv eover the old concrete septic tanks.
   / 3-4 Acre mowing solution #8
JD F-935 diesel, 6' mower deck, really fast ground speed, low fuel consumption, hydro.
   / 3-4 Acre mowing solution #9
If you are willing to accept a few scratches and a few hours on the mower, craigslist is a great source for finding good Kubota, John Deere, and other premium mowers for a price reduction of 1/3 to 1/2 or more. If you can swing a cash deal and are willing to give up the new shine and smell, you can find a great long-lasting machine on craigslist if you are patient and willing to look and haggle a bit.
Yeah, been doin cragslist for months now, only found like new prices or old beat up dogs.
Well if Kubota will finance a second machine, I think I'm going for the Z. F is just too much $ for what I'm gonna use it for and if I did GT I think I'd end up with a mower behind the 3700 anyways for the corrals. That and less time wasted changing the attachments on the 3700. The BX seems great but can't justify a second FEL, and I think the Z will run circles around it for mowing. Looks like it's the 60" Z!
Keep the cash for the old house which had been abandoned and I'm trying to get livable.
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
