3-15 Rear End Oil Seal
   / 3-15 Rear End Oil Seal #1
PaPa3809
Hudson,FL
Terramite
I need the seal that goes on the shaft that comes out of the rear end and joins the the hyd Motor. No number on the seal. Can anyone help, Thanks
Found them
   / 3-15 Rear End Oil Seal #3
great!
will you tell us the number is?
   / 3-15 Rear End Oil Seal #4
Either on the outside or if you depress the lip you can see the size on the inside of a seal .
You can messure the axle (ID) then messure the housing (OD) and the the thickness of the seal . ae 40x60x10mm or 1 1/4x2x3/8
2022 Schulte 2500 Giant Rock Picker (A55314)
2022 Schulte 2500...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
2004 CASE 40XT SKID STEER (A52707)
2004 CASE 40XT...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
