3 1/2 in bore cylinder on wood splitter
   / 3 1/2 in bore cylinder on wood splitter #1
rednck3550
has anyone used a 3 1/2 inch bore cylinder with 1 3/4 inch rod on a wood splitter?i have 11 hp and 16gpm,how would this do with this size cylinder?i have a feeling its gonna be fast but no power,any suggestions?buy new cylinder?use what i have?i dont know what to do.has anyone evr used one setup like this before?thanks for the help in advance:confused::confused:
   / 3 1/2 in bore cylinder on wood splitter #2
3550, yes I have a splitter with a 3.5 dia. cyln. and 1and 3 guarter ram and it works out real well:thumbsup:Dave
   / 3 1/2 in bore cylinder on wood splitter #3
That sounds like about what my Swischer? (spell) is and its rated at 22 tons. Plenty of power for the tough elm here in western Ks.:)
im repowering my old splitter but it has a single stage pump and its slower than molasses on a cold day,so i got a 11hp engine and 16gpm 2 stage pump but wasnt sure bout the cylinder,i live in wv where all the oak and hickory and locust is at and thats primarily what i burn,do you see me having any problems with spliiting power with this cylinder?ive had this splitter for so long and use it so much i just realy dont wanna do this a second time.i think it will be ok if i dont try to split down the middle of a 24inch piece f hickory or locust...what will the cycle time be?should it be pretty fast as well as fairly powerful?
   / 3 1/2 in bore cylinder on wood splitter #5
You only have about 12 tons of force with a 2 stage pump..
Your cycle time will vary . At 16 GPM,
6.4 ips
8.5 ips
at the lower 4 GPM, it will be slower.
1.6 ips
2.1 ips
   / 3 1/2 in bore cylinder on wood splitter #6
Here is the specs on my splitter. Never had any power problems.
7 HP Briggs & Stratton 875 Series engine
22 tons of splitting force
4" x 24" cylinder
11 gallon-per-minute pump for minimum cycle time and faster splitting
Heavy-duty 2-stage pump provides maximum splitting performance
   / 3 1/2 in bore cylinder on wood splitter #7
3550, I,m using a HF 6.5 horse motor with a 11 gpm 2 stage pump and cycle time is about 13 seconds out and just a tad slower back but very useable.It,s never failed to split red oak and I even put a twist in my wedge so no complaints power wise:DDave
ok everyone thanks for the input,i think im gonna try the cylinder i have first and if thats not good enough i'll just switch to a 4 in cylinder.hpefully it will satisfy me,cause i hate to do things twice lol.but i use it enough that i gotta be able to split what i need to,so i'll get it the way i want it eventually.once again thanks for the info everyone
   / 3 1/2 in bore cylinder on wood splitter #9
4" x 24" cylinder
The manufactures are fudging the figures on your system. They do it all the time. The are assuming that the 2 stage pump is pumping at 3000 psi, and even at that, they add a couple tons.
   / 3 1/2 in bore cylinder on wood splitter #10
Log splitters are always faster in the retract mode.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
More info coming soon! (A50323)
More info coming...
2018 FORD EXPEDITION (A51406)
2018 FORD...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
