2wd front tires in mud
   / 2wd front tires in mud #11
In 2wd it generally does not slip on turns - and it doesn't pack up with mud either. I believe it's because of the tread-to-void-ratio, where there is enough void between the tread blocks to discourage the packing of mud. I think it would work OK in your situation, but you might leave indents if the ground is mushy.
Gregg
Thanks. I have never had a problem with the rear AG tires leaving marks, so I should be fine. I think thats the way I will go. Thanks
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
Adams 8 Ton Weigh Hopper (A55314)
Adams 8 Ton Weigh...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
