2WD 855 - What size box blade?
   / 2WD 855 - What size box blade? #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
I have a 2WD 855 that I want to purchase a box blade for. My tractor has some semi slick turf tires. Will I be able to pull a box blade at all or should I have AG tires for that? Should I go with a 4' or 5'?
   / 2WD 855 - What size box blade? #2
The slicks with 2WD will get you no where with a box blade... unless you're just smoothing out some loose material. R1's would do you a little better, but the lack of 4WD will still hamper you ability to do much with a box blade. If you're going to get one, get the 4' with your setup. I can stop my 955 dead in it's tracks with a 5' box blade, R1s and 4WD.
   / 2WD 855 - What size box blade? #3
Really will come down to what you're doing with it. I get stuck pulling my 60" job in 4wd, but that's because I have the scarfer teeth down and catch a root or rock.
Thanks for the reply's. I think I will get a 5' grader blade instead of a box. I've been able to stop it with a 30" dirt scoop but usually a little back and forth gets past the jam. I made a single blade root puller that is working good so if I want to work a rough area I can make several passes with that then come back with the blade.
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
Roller (A52377)
Roller (A52377)
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2012 NOV ROLLIGON CEMENT PUMP TRAILER (A53843)
2012 NOV ROLLIGON...
