2nd oil change coming up..can I switch to Rotella?
   / 2nd oil change coming up..can I switch to Rotella? #1
ArkCivEngr
Russellville, Arkansas
Kubota L3400DT, John Deere X495
I think this is probably a very stupid question, /forums/images/graemlins/blush.gif but I'll ask it anyway because I always seem to learn something on here.
I rolled 90 hours this morning on my L3400DT, so I'll be due for the second oil change in 10 hours. At the first oil change, I got Kubota 15W-40 oil because I was getting transmission/hydraulic fluid and filters at the same time.
I figure the same Rotella I put in my Cummins is as high of grade as the Kubota--if not higher. Or is it? /forums/images/graemlins/confused.gif
And is the price difference enough to even warrant thinking about it? I've just pilfered through my desk (not a pleasant task) and can't find the receipt for the Kubota oil.
   / 2nd oil change coming up..can I switch to Rotella? #2
Since they are both dino oils, you can switch at anytime. You could put a synthetic in without any issues.
Yes, Kubota oil is overpriced. I think it is like $3 per qt. For a dino oil, that is crazy.
Not a stupid question at all either..
   / 2nd oil change coming up..can I switch to Rotella? #3
Now might be a good time to switch to synthetic rotello
   / 2nd oil change coming up..can I switch to Rotella? #4
Isn't Rotalla along the same lines as the Walmart house brand of synthetic, whatever they call it? I'd personally go with the Walmart brand of synthetic over Rotella since Rotella is a "price" oil.
   / 2nd oil change coming up..can I switch to Rotella? #5
Don't you mean Rotella?
</font><font color="blue" class="small">( Now might be a good time to switch to synthetic rotello )</font>
and why is that?
and why would I go down in oil quality?
Also Rotella is not a synthetic here. Only in American can a group 3 dino hydrocracked oil be called a synthetic.
   / 2nd oil change coming up..can I switch to Rotella? #6
compliments of CASTROL and our legal system..........
   / 2nd oil change coming up..can I switch to Rotella? #7
I just switched to Rotella T Synthetic at 88 hours.
   / 2nd oil change coming up..can I switch to Rotella? #8
</font><font color="blue" class="small">( I just switched to Rotella T Synthetic at 88 hours. )</font>
The unvarnished fact is that as long as you find CG-4, or CH-4 or CI-4 on the bottle, you will be fine, and probably a better grade than the Kubota overpriced stuff. That holds for normal or synthetic. /forums/images/graemlins/laugh.gif
I am a synthetic fan, so you can count on me using Rotella T Synthetic or Mobile Delvac 1300 or Mobile Delvac 1, or Mobile Truck and SUV. /forums/images/graemlins/grin.gif
Just a note, Rotella T comes in both normal and synthetic, and the bottles are very similar. Just read the label carefully. /forums/images/graemlins/cool.gif
Another note. While Amsoil may be fine, they have refused to get independently certified for over 30 years. I will consider Amsoil when they get certified./forums/images/graemlins/confused.gif
   / 2nd oil change coming up..can I switch to Rotella? #9
there is a reason why they do not get APi cert. Just like Redline Mobil1R, Maxima, Mobil EP and many racing oils.
I would want an oil NOT to be APi cert since they limits good things in the oil.
To me that is a poor reason not to use it.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
