2hp 8 gal HF compressor issues.
/ 2hp 8 gal HF compressor issues. #1
GREGJR
MILLIS,MA
KUBOTA BX2350, 1968 Wheel Horse Commando 8, Kubota T1600H, T1400H, T1560 40"mmm ,w/T2738 Snowblower,Jacobsen 52" Zero-turn, Humbolt 3 bin bagger,
Hi, My father in law has a HF 2hp 8 gal compressor that is having problems. The motor/compressor runs for about 8 seconds then shuts off. Regardless or how much air is in tank. After reset trips, a few seconds, I can press it and motor starts up again. Then it shuts off after 8 seconds or so. i tried to run it with empty tank and drain valve open. No difference. I realize it is a cheap compressor, but I would like to figure it out. Not many hours on unit. Any ideas? Thanks
Thank you, I did some tests and all things point to that.. one on order...Thanks
/ 2hp 8 gal HF compressor issues. #4
I've got that compressor. It performs VERY poorly on a 15A circuit or with any extension cord, even a 12 ga one. Try a 20A circuit and no extension to see if it makes any difference.
/ 2hp 8 gal HF compressor issues. #5
EXactly
I have that compressor too, and thought the very same thing.. bad start / run capacitor as it was stripping all over the place.
It simply doesn't like long branch run 15a circuits on 12/14-2 wire.. and it doesn't tolerate extension cords unless they are some home made cords that have something like 10g stranded wire and end up being as big as your thumb, or are home-made jumpers to go from outlet to pump made by putting hd ends on a piece of 10-2.
Int he end.. it doesn't like small wire and lots of plug connections.
as a test.. plug it into a dedicated circuit capable of 20a like your washer or refer circuit.. see what it does.
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Kinze 3600 Wiring Harness (A65640)
Kinze 3600 Wiring...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2000 Ford F-350 (A66408)
2000 Ford F-350...
1996 International Paystar 5000 Log Truck (A62679)
1996 International...
