2cyl. vs. 3cyl.
   / 2cyl. vs. 3cyl. #11
It no longer disengages, and it happened as I was using the tractor. I need to split the tractor and see what is wrong, but as I have bought a IH 3414 backhoe I have sidelined the yanmar from moving fill.
   / 2cyl. vs. 3cyl. #12
Brett,
Yeah its the YM1301D we unloaded. It is such a sweet tractor. I just wish it was powershift. Right now I have the loader and belly mower off, and a 4ft front blade on it. I've already plowed a bunch of snow with it. You can see some really good pictures at <A target="_blank" HREF=http://www.geocities.com/gregbirkymustang/>my website</A>. Right now I'm working on relocating the electric clutch to under the hood below the battery. The current location is in front of the front bumper and interfers with the loader. When I'm done, the belly mower and the loader should be compatible. I'll still have to do a little modification to the loader subframe due to interference with the deck.
I put a block heater in it, but haven't had to use it yet. It has started as cold as about 25deg F with just the thermostart.
I attached a photo here too.
   / 2cyl. vs. 3cyl. #13
Does your throw out bearing make noise or otherwise feel horrible when you push the clutch in?
   / 2cyl. vs. 3cyl. #14
No noise when I push it in, however right after the clutch went out, it made a noise while I drove it back. That noise is not there now with the clutch in or out.
toro turf sweeper (A50324)
toro turf sweeper...
Hutchinson 10" Transfer Auger (A50514)
Hutchinson 10"...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
2019 BOBCAT E35I EXCAVATOR (A51242)
2019 BOBCAT E35I...
2014 Ram 1500 (A50323)
