2940 lift doesn't work
/ 2940 lift doesn't work #1
roach7991
Bullard, TX
John Deere 2940
I have a JD 2940. Hydraulic fluid is good, but when trying to operate lift, it jerks or doesn't work at all. the steering is very hard to turn at any time.
/ 2940 lift doesn't work #2
Double check the fluid and after that the filter. Filter is a biggie. If that dont work you need to get a manual and test the hydraulic system pressures to isolate the problem. Could be a pump issue. There are screens in the pump valve ports that can get clogged or broken, causing valves to get stuck. Get a manual for the diagrams.
