2940 electrical problem - wiring diagram?
   / 2940 electrical problem - wiring diagram? #1
edjones72
South Georgia
Yanmar YM2210, Cub Cadet 2166, JD2940, Mustang 440 skidsteer
I have a 2940 that periodically looses electrical power to the dash. When this happens, there is NOTHING: No lights, gauges, or ignition power. When it first happened I thought the batteries were dead. Hooking a 200 amp jumper to it did nothing. Then eventually you here the "click" of a relay and power is restored. It generally does fine after cranking but the other day while running all power quit to the dash and the battery light came on. I shut it down for fear of cooking an alternator or voltage regulator and then the power did not return to restart. I cussed, stomped, and snorted for a few minutes turning the key and any other thing I could find. Just before giving up, "click" and the power came back on and I drove to the barn without problems. These kind of gremlins drive me insane. Any help would be greatly appreciated and a wiring diagram would be welcome, also.
Eric
   / 2940 electrical problem - wiring diagram? #2
I would look for loose connections. If you can locate this relay, Check it's terminals for loose/corrosion. You also may have a bad/worn ignition switch, try wiggling the key when the problem happens. Check with the service manager at your JD dealer, he should be able to print out a wiring diagram for you. You may want to replace the relay if none of the above help
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
2015 Ford F-150XL (A53314)
2015 Ford F-150XL...
1992 VIM TRAILER MFG CRUDE TRAILER (A55745)
1992 VIM TRAILER...
