2910 Tiltmeter
   / 2910 Tiltmeter #11
Hi Guys, Rick here at R&B.
All Tiltmeters are designed to read properly when VERTICAL
only. A slight tilt of 5 degrees forward or backwards is allowed.
Anything more will give a false reading. PLEASE mount any
meter vertically. If the 2 "L" shaped mounting brackets do
not work for you, I have a new style bracket that should.
If ordering, please ask for new style if needed. No extra
charge. Anyone that has "L" shaped brackets that will not
let you mount where you like and still be vertical, let me know.
I will send you a new style. Now, about the #51 dual dial
tiltmeter. Good meter. Dials are too small for practical use on
tractors. Designed for other applications. Not tractors. I have
sold a few to tractor owners, and they seem to like them, but
most say they are too small dials. The best models are
either the 25C, or in few cases, the 7489C. Both work well
on tractors. Both C versions are painted to show caution and
danger points using A.N.S.I standards. Note; these are
standards only. Your applications may vary, due to fel, wheel
weights, filled tires, etc. Thanks Guys. Rick
Rick Hedgecock
R&B Manufacturing
http://www.tiltmeter.com
(816)587-9814
   / 2910 Tiltmeter #12
<font color=blue>best models are either the 25C, or in few cases, the 7489C</font color=blue>
And I have the 25C for side to side and 7489C for front to rear. May or may not really need a front to rear, but I like'em that way./w3tcompact/icons/smile.gif
   / 2910 Tiltmeter
Rick
Thanks for information. I have repositioned my Tiltmeter toward hood about ¾". This allows me to straighten "L" bracket to a vertical position. I used brackets supplied with long leg attached to dash. This allows some movement of brackets and puts Tiltmeter as close to dash as it can be. I needed to get mounting bolts away from gauges to get clearance for mounting bolts. Your have a great product. Thanks for your concern.
   / 2910 Tiltmeter #14
Hey thanks! Here where I live the hills are so steep that I would mostly be going up and down thats why the Model 51 was most appealing , mainly because I could (hopefully) mount it where I could see it rather than off to the side(no canopy yet).
BTW -Tractor should be here Sunday morning. Cant' wait!
   / 2910 Tiltmeter
Cornflake
Tractor delivery on Sunday?/w3tcompact/icons/shocked.gif Where is this dealer located?/w3tcompact/icons/smile.gif My dealer isn't even open on Saturday this time of year./w3tcompact/icons/frown.gif
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
