Byra
I am trying to decide between these 2 tractors.
Ill be using the tractor on my 80% wooded 17 acres for bushhogging about 2 acres, maintaining about 1000' of driveway, clearing some trees, hauling wood, tilling a garden plot, and general maintenance.
As far as implements go, i think im going to need a brushhog, a loader, a boxblade, and a backhoe to start with.
The 2810 is over 400 lbs heavier, but has less HP, less lift capacity, and a smaller implement hydraulic pump. Other than that, I dont see much difference between these tractors.
Unfortunately, my local dealer doesnt have either in stock so I cant check either out in person without going for a long drive.
From the posts Ive read here, it seems the 3015 is a bit cheaper than the 2810.
Is there any reason to pick the 2810 over the 3015?
Thank you for your advice!
--Byra
--Byra
