2810HST hydraulic filter
   / 2810HST hydraulic filter #1
shvl73
Banned
NH
Mahindra 2810HST
Wix lists a 51621 filter for the 3510 but doesn't list a filter for the 2810, Does anyone know if they use the same hydraulic filter?
   / 2810HST hydraulic filter #2
The 2810hst uses a different filter than the 3510 it has a spin on filter located next to the hst motor in the opening under the tractor. This filter is very expensive through Mahindra but i have a Napa part number-1586 this filter can be purchased for half the OE price.
Thanks for the info, another poster, Dieselsmoke, found the same part # & I found it in stock at the Sanels parts store in Concord. I was suprised it wasn't a metric thread. It's been said that it can be awfully tight. I hope it comes off without a lot of cursing.
Would you know a Wix or Napa part # for the oil filter?
I've been able to find the same thread & gasket dimensions but I'm unsure about the by-pass valve PSI & what role that plays.
Thanks for any info you can provide.
   / 2810HST hydraulic filter #5
I know several people using a napa 1626 oil filter on the mahindra compacts i am not sure if the by-pass is exactly the same,maybe someone will write back with more info.
Kubota R530 (A50120)
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
Truck Bed (A50774)
Truck Bed (A50774)
2008 Caterpillar 906M Compact Wheel Loader (A50322)
2008 Caterpillar...
