26x12-16 Zero tire failures. Does anybody make 6ply ?
   / 26x12-16 Zero tire failures. Does anybody make 6ply ? #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I destroyed the sidewall last summer.
Something punctured a big hole in one this afternoon.
This is two that’s failed.
Almost $300 a pop ain’t cheap.
I limbed the ZD1511 a 1/4 mile back to the shop & pulled out the ZD1611 to continue to mow until dark.
These mowers are super heavy & need a tougher tire especially mowing horizontally on these steep banks.
Any ideas ?
I don’t want to swap down to 12” wheels as both of my mowers have 16”
   / 26x12-16 Zero tire failures. Does anybody make 6ply ? #3
Does anyone have airless tires for these.? I have to air mine up ever time I start to mow.
I’ve heard the Tweels doesn't hold up well with the ZD1211 & bigger machines because they are so much heavier.
Idk personally myself tho.
I don’t use them because I run fluid filled rears with 140lbs of weight on front axle for my steep banks.
   / 26x12-16 Zero tire failures. Does anybody make 6ply ? #5
Mine are filled with a sealer. I don't know if I've ever punctured them, because they automatically seal
   / 26x12-16 Zero tire failures. Does anybody make 6ply ? #6
Get them foam filled. There is a foam that you can fill them with that adds weight and will allow you to run them bald! It also isn't the hard type, it's a softer fill that won't jar your teeth.
2012 International Derrick Digger (A55973)
2012 International...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
