267-H drive belt.
   / 267-H drive belt. #1
pipefitter
Chester, VA
Kubota BX 23
I have a Wheel Horse/Toro 267-H and probably need to change the drive belt on it. I've read that it's a pain in the rear. Is it as bad as I've been told and if so, are there any short cuts?
   / 267-H drive belt.
Well, I changed it. Like the book says, it needs to be raised in order to do the job. I would suggest about 1.5 to 2 feet off the ground. Then place some dry leaves, straw, or pine needles under it. Set the leaves on fire, walk a safe distance away, and enjoy a cold beer as that crappy designed POS goes up in flames. Phew!
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54313)
2014 FREIGHTLINER...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light (A52377)
2019 Allmand Bros...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
