2640 Brakes
   / 2640 Brakes #1
Grants351
Does anyone have any info on the brakes of a JD 2640? Currently having an problem where the brakes have to be pumped to get any braking power, and sometimes that will still provide nothing. Do they use hydro oil for the brakes? Consider me a novice on this, just looking for any kind of info so i can look into this. Thanks
   / 2640 Brakes #2
Hyd trans pump fills brake valve reservoir then hyd oil is utilized similar to brake fluid. I'd suggest to bleed brakes. Bleeder is located on the inside top of axle housing. If bleeding doesn't help then I'd suggest to cap brake lines to see if brake valve will pump up & hold.
   / 2640 Brakes #3
First bleed brakes and if still on brakes .......then test by depressing one pedal very fast and then slow .......if you have brake on one pedal when depressing very fast but slow nothing..... then the valve inside is no good and needs replacing
Then do same with other pedal .
   / 2640 Brakes #4
Remove the brake line from the brake valve ,with a hand pump, pump up the brake to 100 P S I and see if maintains pressure if it doesnt you have leaking O
rings on the brake piston.
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
