Mowing 2638 HST Cab A/C
   / 2638 HST Cab A/C #1
567Chief
Central Virginia
Ford 2000 (1965) Ford 801 Power Master (1958) Farmall Super-A (1949) 1740M
I’ve been doing a bunch of research and I’m about to pull the trigger on a 2638 cab. I ran across a review that said the a/c could not keep up on a warm day. They also said the HST pedals were not comfortable for operations like mowing. Can anyone with a 2638 give me their review? Thanks!
   / 2638 HST Cab A/C #2
I don't have a cab, so can't comment on the ac. With only 50 hrs. on clock I have no problems with the pedals, did not like the rocker setup some tractors have. the only thing for me was as this was my first tractor i was so used to gas and brake on cars and trucks I instinctively pushed the wrong pedal at first,can be bad in tight conditions. Short learning curve though. I did a lot of research too. I am really happy with it. It's more powerful than i was expecting. I've got hours of bush hogging,dug post holes, loader work, tilling, box blade work. Pallet forks are very handy.
   / 2638 HST Cab A/C #3
can't comment on the A/C yet.. the heater works good tho! you can get a cruise kit installed at dealer. it's a very simple magnet setup.
   / 2638 HST Cab A/C #4
I used the a/c this summer in the 80's and full sun. Had no problem and was real nice. As far as mowing, I have only done loader work until I use it for snow this winter. I think it would be okay though, the cab is sorta small (don't find it horrible at 6 feet) but I can get my feet right over the pedals and use them easily.
   / 2638 HST Cab A/C #5
i ended up modifying my brake pedals. i shortened them up about 1.5".. i made it so the factory lock stayed put. just moved the flat pedal back far as i could so the lock worked as is. made a absolute huge improvement for me with my big feet. a lot easier getting in and out too! but they are a "CUT". i suppose you can only cram so much stuff in a certain size lol. but i agree, it isn't all that horrible.
i moved the seat back 1.25" also. feels a lot more comfortable now. all in all i pretty happy so far. minor adjustments are no biggy for me.
   / 2638 HST Cab A/C
I appreciate all of the replies but I’m still wanting to hear from someone who has operated the 2638 hot temperatures. I want to be sure that when I’m mowing and it’s 95 outside, the a/c will keep up.
   / 2638 HST Cab A/C #7
For the pedals if you're doing any extended mowing then get the cruise control option added. It's about $200 to add the option when you're buying the tractor and it only takes about 15 minutes for the dealer to install it.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2011 Chevrolet Tahoe SUV (A55853)
2011 Chevrolet...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
403 (A52706)
403 (A52706)
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
