2615 Toolbox
   / 2615 Toolbox #1
BamaRob
Platinum Member
Alabama
Mahindra 2615 4WD
I have mounted two .30 cal ammo boxes on the fenders of my 2615. I simply drilled two holes in the bottom of each box and used the existing holes in my fenders (took the handholds off). These work great. They have lots of room and are the perfect size to fit on the fenders. I keep tools and gloves in one and chains, hooks, other attachment items in the other. I only have one problem with the boxes mounted here... I hit my dadblamed elbows on them all the time! So, I'm thinking I need to find another location.
I'm considering added a cross member to the ROPS and mounting the toolbox there. Before the ROPS police starts... I do not plan to drill any holes in the ROPS. Nor do I intend to weld on the ROPS. If I go this route the cross member will be clamped on to the ROPS in some fashion.
Another option is to mount them on the loader frame structure some way.
Any opinions? Suggestions?
I'll try to remember to post some pics of my current set up this afternoon.
Thanks,
BR
   / 2615 Toolbox
Thanks,
BR
   / 2615 Toolbox #3
BamaRob,
If mounting to ROPS, try the squared U-bolts, like used for trailer axles. They come in different widths and bolt lengths.
I had my local shop thread and bend from stock when I needed some for my boat trailer. You wouldn't need near as heavy for the ammo boxes, but you may want to get the heavier ones for the Browning...heh-heh /forums/images/graemlins/grin.gif
-DiskDoctr
   / 2615 Toolbox #4
BamaRob,
-DiskDoctr
   / 2615 Toolbox
</font><font color="blue" class="small">( ...but you may want to get the heavier ones for the Browning))</font>
Huh? What Browning?
I've pretty much decided to mount my tool boxes on the quick hitch that I ordered from Harbor Freight the other day.
Click here or here for the thread on the quick hitch I ordered. And, here's the way I intend to mount my tool boxes (thanks to JD3520 for the idea):
   / 2615 Toolbox
Huh? What Browning?
   / 2615 Toolbox #7
BamaRob,
I figured if you had the .30 cal ammo boxes, you must be getting prepared for the .30 cal Machine Gun /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Thanks for the pic. I have a few ammo boxes and was looking briefly but didn't find a good place to mount it. I really like the quickhitch mount area- will probably do the same thing you are.
One thing, I'll probably put it on the other side. I usually connect the PTO shafts from the right side and it could be in the way.
-JC
   / 2615 Toolbox #8
BamaRob,
-JC
   / 2615 Toolbox
</font><font color="blue" class="small">( I figured if you had the .30 cal ammo boxes, you must be getting prepared for the .30 cal Machine Gun)</font>
Oh... the reference to Browning went right over my head... makes perfect sense, now. /forums/images/graemlins/laugh.gif
Good call on the location of the box inhibiting access to (dis)connect the PTO shaft. Since I have two boxes, currently with one mounted on each fender, I was going to put them both on the quick hitch. I may have to rethink that and only put one on the left side. Hmmm. I may mount one on the right and see how much it's in the way when messing with the PTO.
Thanks,
BR
   / 2615 Toolbox
Thanks,
BR
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2011 PETERBILT 367 T/A DAY CAB ROAD TRACTOR (A51243)
2011 PETERBILT 367...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
