Mowing 2615 pto stopped
/ 2615 pto stopped #1
pw42
cleveland tx
mahindra 2615
Hi all looking for help on mahindra 2615 first off my pro stopped? Any one know about these thanks pw.
/ 2615 pto stopped
Thanks for reply (mowingl.
/ 2615 pto stopped #5
did the pto really stop.. as int he tractor stub pto will not spin.. or is the shaft spinning but the mower not spinning? post back.
/ 2615 pto stopped #7
Is it the rear or mid PTO and have you checked the linkage the PTO lever connects to.
/ 2615 pto stopped
It's the rear pto output shaft runs attachments the pto lever linkage looks good just not working?Also any one have a Manuel /where to split tractor to fix this?
/ 2615 pto stopped #9
Have you checked it with nothing attached? Does this model have an internal orc?
/ 2615 pto stopped #11
internal orc or not? if an internal one. it my have let go!
/ 2615 pto stopped
Oh I don't know if it has a internal orc?
/ 2615 pto stopped #13
got an exploded diagram of your machine?
/ 2615 pto stopped
No but I wish I did I'm thinking a busted gear ?
/ 2615 pto stopped #15
Or a orc that detonated... Does your service or parts manual not have exploded parts diagrams?
/ 2615 pto stopped #17
The ORC (over running clutch) on the 2615 can get stuck if it takes a good hit while running a rotary mower. Especially if the operator has replaced the shear bolt with something tougher than proper. Like putting a 60 amp fuse where there should be a 15 amp fuse... But even without shear bolt issues, we have seen this a few times over the years on the 100's of 2615/2816's we sold that had this style ORC. (They went away from this style and went to a silent non-ratcheting type later....which was good and bad).
It has a spring setup inside that holds a coupler together. It has ramp shapes in one direction and straight cut in the other. When applying power to the PTO, the straight cuts are together. If the implement tries to power the tractor (such as in a rotary mower situation when you power down or de-clutch), the ramped portion rides up and makes that ratcheting sound. But if it hits the ramp going 90 mph, figuratively speaking, it chucks the one half of the coupler back so far that it gets stuck on the shaft where the machined portion is slightly larger. Rarely happens, but we have seen it a few times.
HST or gear model? I'm guessing an early HST model as they had this style of ORC.
/ 2615 pto stopped
I belive mine is the gear model how do I get to these parts to replace or fix them any help thanks for reply pete.
/ 2615 pto stopped
Also under the seat I opened the square access there's a shaft spinning until I engage pto small 540 lever it stops? If I push shaft back it slides inside a piece ?
/ 2615 pto stopped #20
If it is a gear model, that changes things. Open your fill plug for the transmission and look into the hole with a flashlight. Look at the top shaft, look towards the rear of the tractor. The shaft goes into a coupler. If any part of the shafts splines are showing then you have identified the issue as the shaft has come uncoupled that runs the PTO. In theory you can recouple it through the hole, but as a practical matter it is nearly impossible to squeeze back together. The replacement parts, if you do tear it down to replace, are a little different and do not ever come uncoupled. We've sold hundreds of 2615/2816 so we have seen this a few times. If you have a high volume dealer nearby he has probably seen it as well. Rare, but it happens. Typically you split the tractor, install the kit and button it back up.
2006 Ford E-350 Enclosed Service Van (A59230)
2006 Ford E-350...
iDrive TDS-2010H...
159119 (A60430)
159119 (A60430)
golf cart (A56859)
golf cart (A56859)
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
