2615 Hydraulic filter/fluid
/ 2615 Hydraulic filter/fluid #1
dtsdryseats
South Lyon Mi
Mahindra 2615
:confused: I have a 2615 (gear) tractor. I recently replaced the hydraulic fluid and filter for the first time. I used a wix 51663 filter and traveler universal hyd fluid from TSC
Traveller Universal Tractor Trans/Hydraulic Fluid, 5 gal. - 0806391 | Tractor Supply Company
It may be in my head but it almost seems like I am getting a hyd pump cavitation at higher RPM's now? The Wix filter is about 1/3 again shorter than the stock filter and I am not 100% convinced that the fluid is correct, though the dealer I bought it from recommended any 32 hydraulic fluid?
Can anyone enlighten me on my situation?
Thanks!
/ 2615 Hydraulic filter/fluid #2
Thanks!
You probably are cavitating the pump, and that is real hard on pump life. I'd use the factory filter. I'm not familiar with the specs on the TSC hy-trans, we recommend the factory branded Mahindra Hy-Trans, or Chevron THF-1000 or Mobil 424.
