Mowing 2615 HST-Problems W/ Finishing Mower Woods RM 660
   / 2615 HST-Problems W/ Finishing Mower Woods RM 660 #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I bought a used Woods RM 660 finishing mower a few months ago and have used it about three times. My finishing mower has three blades. The middle blade is cutting grass about 1 inch lower than the two outer blades. Do I need to adust something?
   / 2615 HST-Problems W/ Finishing Mower Woods RM 660 #2
I doubt there is any adjustment that can be made to solve the problem, but an inch should be easy to see what the problem is if you take a look at the bottom side of the mower. The problem could be an incorrect spindle or blade, a bent deck. Good luck with it.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
585-343-0770
   / 2615 HST-Problems W/ Finishing Mower Woods RM 660 #3
What Galen said - plus - check to see if either the center or the 2 end blades are upside down. On the deck of my lawn tractor I once put one blade upside down after sharpening. Cut at a different height and left a "stringy" appearance because it was using the back edge of the blade instead of the sharp edge. Doesn't cut well that way. /forums/images/graemlins/blush.gif
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
2018 International DuraStar 4300 26FT Box Truck (A55852)
2018 International...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
2015 Freightliner Sprinter 3500 Cargo Van (A55852)
2015 Freightliner...
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
