2615 gear question
/ 2615 gear question #1
drg1
Missouri
1532 hydro
excuse my ignorance but a couple basic questions...looking at a 07 2615 gear tractor..is the transmission a shuttle type in these and if so how does it work, also how is the pto operated and contolled? Was searching for ownerns manual to download so I wouldnt have to ask these basic questions...Tractor is a couple hours away and trying to get all the info on it before I chose to look at it...Thanks
/ 2615 gear question #2
It is a 9 x 3 transmission, not a shuttle. Reverse and 2nd are across from each other so back and forth between the 2nd and reverse is easy. The PTO enguagement is simple and reliable, push the 2 stage clutch pedal, all the way in, shift the pto lever into gear and let out the clutch.
ok got and thanks for the quick reply:thumbsup:
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
YALE FORKLIFT (A63291)
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
2015 JLG 3394RT ROUGH TERRAIN SCISSOR LIFT (A65053)
2015 JLG 3394RT...
