2610 won’t start
   / 2610 won’t start #1
Frank6596
Kioti 2610
I have a 2021 kioti 2610 and I’m having an issue with it starting. I have power so it’s not a battery issue. I am getting a clicking noise on the front right of the engine clutch is in I’m sitting in seat and in neutral There are so many sensors on this thing I unplugged seat sensor plugged it back in still nothing, removed the ignition switch put some warm air to it, nothing any ideas
   / 2610 won’t start #2
You might have power but a loose cable will do that , My cub cadet somehow will get loose often.
   / 2610 won’t start #3
What is the battery voltage? Clicking could be the starter solenoid, fuel solenoid, glow plug relay, etc
As gunr said, if the battery is ok, a loose pos or neg cable will do that.
   / 2610 won’t start
I will check battery voltage and starter solenoid tomorrow thanks
   / 2610 won’t start #5
As others have said a poor or loose ground or positive connection will show voltage to the solenoid but without a solid connection it will not allow full current to the starter solenoid. It might show 12.8 V but its weak.
   / 2610 won’t start #6
Either loose wire is giving a poor connection or your battery cannot support a high Amperage load. Do a visual on all connections, tighten them down and spray and clean. To evaluate the battery health, check voltage before and during a load. You can also hookup a charging jumper cable from your car battery and that should provide adequate amps to start the tractor. If it starts, then your battery needs full recharge or replacement. Cold temperatures also reduce battery voltage.
   / 2610 won’t start
It was the seat sensor why it’s at the edge of the seat is beyond me I guess I can’t sit back in the seat
   / 2610 won’t start #8
Seat sensor? While standing next my/same tractor, HST, I can just push down on the clutch with my left hand, and turn the key with my right hand, and it cranks/starts. Is yours a CAB tractor? Details...
   / 2610 won’t start #9
Same here as 34Willys stated. What seat sensor?
   / 2610 won’t start #10
As far as I know, a seat sensor will not prevent a tractor from starting as long as it's out of gear and/or the parking brake is on and the PTO is off.
It will shut the tractor down if you get out of the seat while the tractor is in motion or the PTO is on. Some machines will allow you to raise (tip the seat forward) and use PTO powered accessories.
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 7 (A53084)
2024 JOHN DEERE 8R...
1840 (A51248)
1840 (A51248)
