2600 series cab model- front turn signal wire- Where is it?
   / 2600 series cab model- front turn signal wire- Where is it? #1
OldTrix
none
Had a run-in with sapling on my 2665. Mashed the ft left signal. Got a new one. Rather than a simple plug at the back of the lamp assy, I get a 3 foot longish cord with bullet connectors. looks like it comes across that front frame piece that separates the upper and lower front glass. It's blank sheet metal behind the dash, and on the engine side of the firewall, there is a harness that runs the perimeter of the cowling, but where the front piece meets the frame, it's blanked off. No sign of any wire from the indicator. The line is to short to reach the roof, and seeing nothing at the bottom where the AC lines go up.
Has anyone done this repair? Where does the wire plug in?
Found it, well hidden out the bottom. There are two clear plastic hoses for AC drains, it was cleverly braided in between.
Don't forget to tie off a stout string to the old one when you pull it out- You'll need a bit of fiddling to get the new one past those hoses.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
