Backhoe 260 Backhoe
/ 260 Backhoe #1
Mtn.Mike
Northcentral Pa.
JD 2305
I'm a "noobie" here on the site but I've been "lurking" for some time. I have a 2305 and recently put on the above backhoe to include the "subframe".
I did it in the record time of 8+ hours but at least it fits and works. :D
Unfortunately I am in the dark about what I have to remove from the 3 pt. hitch so I can put the hoe on quickly and I don't what to have to take off more then necessary.
Could anyone bring me up to speed?
Thanks, Mike
/ 260 Backhoe #2
mike
this is a year plus late but...
on my 2210 w/ 260
remove the mmm
raise the 3pt to it's highest position and set he mmm deck height dial to "lock"
remove the lower 3pt arms and install 2 spacers; supplied with my tractor; on the shaft in the same location from which the arms were removed - no need to remove the tires as the shaft slides side to side
remove the top link if installed
no need to remove the assembly that uses the 3pt to raise and lower the mmm that runs along the left side of the frame as in the locked position the 206 frame will just fit
total time 15min
tkoza
PALLET OF MISC ITEMS (A67714)
PALLET OF MISC...
CATERPILLAR WHEEL LOADER (A65053)
CATERPILLAR WHEEL...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
MAHINDRA 2655 TRACTOR (A65057)
MAHINDRA 2655...
2022 John Deere 450K LGP Crawler Tractor Dozer (A66734)
2022 John Deere...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
