2565 PTO Leak
/ 2565 PTO Leak #1
Eagle Keeper
Dublin, Georgia
2016 Mahindra 2565
I noticed my PTO shaft has a slight hyd oil leak. Has anyone with a 2565 Mahindra had to change their PTO seal? If so, any tips? Do you know the part number?
/ 2565 PTO Leak #2
I took a look at my 2565, it has a slight leak but nothing I am going to worry about.
It looked like there is a plate you can remove to replace the seal. Not sure if the seal is mounted in the plate or under the plate but it didn't look like it would be a big deal to replace. I can't help on the part number but you can probably just get the old seal out and have a local parts store get a new one.
/ 2565 PTO Leak
Thanks Reb954. Mine also is a minor leak. I was just thinking being it is winter and i'm not using the tractor much this time of year, i may attempt to replace the seal.
/ 2565 PTO Leak #4
I figure the seepage is caused by vibration carrying through the drive system from whatever implement is being used, snowblower and mower in my case, so even if I changed the seal it would probably still leak.
