2555HST Low rpm
   / 2555HST Low rpm #1
SC2555HST
While moving brush with grapple for about 30 mins, I attempted to raise rpm's. With lever all the way down to full throttle, it would not go past 1500. I turned off and restarted 3x. No change. I turned it off and waited approximately 30 mins, and started her up and all is well. I ensured air filter was clean, which it was. Any idea what would cause this? It has happened before also.
   / 2555HST Low rpm #2
This is a shot in the dark as I have no idea on that model-
Some engines- especially computer controlled ones- won't allow the motor past a certain RPM if the PTO is engaged. If the PTO was engaged or the computer thinks it's engaged it may not allow higher RPMs. It would take a switch adjustment or replacement if the PTO wasn't engaged.
   / 2555HST Low rpm
PTO was not engaged. I was running a bush hog prior to grappling and it went all the way up to highest setting. Stopped bush hog and started grappling.
   / 2555HST Low rpm
It's happened about 4-5x in 170 hours. Weird.
   / 2555HST Low rpm #5
The 2555's need a reflash and have had some EGR problems. Has yours been reflashed? This is a known problem
   / 2555HST Low rpm
It has been reflashed.
   / 2555HST Low rpm #7
The other shot in the dark would be the TPS/APPS (something that tells the computer the throttle position). With zero info about Mahindra motors from the dealer I'd just check it with an ohm meter. You may see a flat or dead spot - especially as you tap/shake/move the sensor.
I'm still wondering how the PTO/engine speed ties together.
   / 2555HST Low rpm
I was referring to the tach, it says 540pto on dash.
   / 2555HST Low rpm #9
The only time I ever had this happen was below 20F degrees during startup and when the tractor overheated - the computer will not allow the engine RPM's to raise until it is safe to do so.
   / 2555HST Low rpm #10
Hmmm same vain- computer getting false data that prevents going over a specified RPM.
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
198367 (A51243)
198367 (A51243)
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
