2555HST Low rpm
   / 2555HST Low rpm #1
SC2555HST
Bronze Member
While moving brush with grapple for about 30 mins, I attempted to raise rpm's. With lever all the way down to full throttle, it would not go past 1500. I turned off and restarted 3x. No change. I turned it off and waited approximately 30 mins, and started her up and all is well. I ensured air filter was clean, which it was. Any idea what would cause this? It has happened before also.
   / 2555HST Low rpm #2
This is a shot in the dark as I have no idea on that model-
Some engines- especially computer controlled ones- won't allow the motor past a certain RPM if the PTO is engaged. If the PTO was engaged or the computer thinks it's engaged it may not allow higher RPMs. It would take a switch adjustment or replacement if the PTO wasn't engaged.
   / 2555HST Low rpm
PTO was not engaged. I was running a bush hog prior to grappling and it went all the way up to highest setting. Stopped bush hog and started grappling.
   / 2555HST Low rpm
It's happened about 4-5x in 170 hours. Weird.
   / 2555HST Low rpm #5
The 2555's need a reflash and have had some EGR problems. Has yours been reflashed? This is a known problem
   / 2555HST Low rpm
It has been reflashed.
   / 2555HST Low rpm #7
The other shot in the dark would be the TPS/APPS (something that tells the computer the throttle position). With zero info about Mahindra motors from the dealer I'd just check it with an ohm meter. You may see a flat or dead spot - especially as you tap/shake/move the sensor.
I'm still wondering how the PTO/engine speed ties together.
   / 2555HST Low rpm
I was referring to the tach, it says 540pto on dash.
   / 2555HST Low rpm #9
The only time I ever had this happen was below 20F degrees during startup and when the tractor overheated - the computer will not allow the engine RPM's to raise until it is safe to do so.
   / 2555HST Low rpm #10
Hmmm same vain- computer getting false data that prevents going over a specified RPM.
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
1028 (A51572)
1028 (A51572)
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
378802 (A51573)
378802 (A51573)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
