2555 INPUT SEAL/ BEARING FAILURE gear trans
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #1
melroebobcat
USA
BOBCAT
Had a outer bearing failure on 2555, shaft bearing and other components have to be replaced pictures attached. anyone heard of this happening at 75 hours?
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #2
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #3
I agree thats way to soon for that kind of failure.Ive worked on a bunch of tractors that lived very rough lifes with very little maintainance and have not seen something like that.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #4
Sounds like a warranty claim to me.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #5
yep thats what a warranty is for... Even the big names have it happen occasionally. Lost a $20,000 turbo on a caseih after less than 1000 hrs. covered under warranty.
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #6
That's not many hours for that kind of a failure. I'm beginning to wonder about the TYM made stuff.
I have not seen any real problems with the TYM machines. The Mahindra ones have had EGR problems. But this problem appears to the first that I have seen.
yeah exactly, this tractor just needed the update and then as soon as I got done test driving it for 4 mins 30 seconds it gave out after tractor was shut off... it went from a drip every few seconds to complete loss of oil in between front-center case. it had no leak ... our shop foreman was about to shut it off and I insisted on test driving very briefly as usual. and it so happen to give out luckily before we returned the machine to the customer 1HR and 10Mins away. All parts + the case $1650 actual cost to Mahindra maybe $1000. 20 hour job
   / 2555 INPUT SEAL/ BEARING FAILURE gear trans #8
At least it will get taken care of before the customer has to deal with it. Unlike some poor souls. Wow 20 hours work for a 2 dollar seal. Kinda glad now that my machine was a Mitsu build.
I will say This!
Mahindra Stands behind there tractors. Never had an issue with warranty approval. The 2555 tier 4 model was a little before its time. All the kinks have been worked out. I recommend buying a HST Over Gear For sure. I will post some pictures of rebuild for those who are interested. ALso ill post picture of all parts that have to be replaced with a mid case overheat.
Wacker Neuson Diaphragm Pump (A50325)
Wacker Neuson...
Year: 2013 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 144,857 Plate: (A51694)
Year: 2013 Make...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Has charger with it. (A51694)
Has charger with...
