Ballast 2555 ballast box/counter weight
   / 2555 ballast box/counter weight #1
Sarge338
Mahindra 2555
Good Evening,
I have a 2555, and I have to move a lot of gravel soon. I am looking for any advice around building a ballast box (dimensions), and what kind of weight to use. I have looked for a suggested counterweight value, but I have not found one. The tractor has a Cat 1, 3 pt hitch.
I was thinking of just welding the pins to a rebar skeleton, and then pour some concrete around that skeleton. What do you think?
Thanks for the input!
   / 2555 ballast box/counter weight #2
If you have far to go with it, maybe a 30" pond scoop would work?
David from jax
   / 2555 ballast box/counter weight #3
Good Evening,
I bought one from Titan Attachents it’s Cat 2 I use QH on my Cat 1 3pt hitch they have Cat 1 model 5.3 cu ft be like 800 full of concrete.There Cat 2 the one I have is 7.2 cu.or 54 gallons full of concrete is like 1,270 lbs. You could take a 55 gal drum and fill it with concrete and weld 3 pt frame connect to it.It’s been done by many !!
   / 2555 ballast box/counter weight #4
Or use a 55 gallon drum and cut a hole in it on each side, and slide one of those tow bars thru it. If it is the right lenght, you won't have any welding to do. A hammer and cold chiesel is all! Justmake sure of correct length before you atart cutting!
David from jax
   / 2555 ballast box/counter weight #5
I haven't had a need for anything but my box blade. Figure it's probably 500 pounds.
Thanks for all of the suggestions! I will try my box blade… that may be enough. Otherwise, I kind of like the drum of concrete idea. That should get the job done! I guess I was over-engineering again. Lol
   / 2555 ballast box/counter weight #7
And, if the box blade isn’t heavy enough on its own, you can weld a bar on it to take suitcase weights, or wieght lifting weights, or well stem full of concrete, or anything else you might think of that is heavy.
   / 2555 ballast box/counter weight #8
Where are you from? I have some barrels of concrete filled already That I would let you borrow if you were close.
Your 2555 is about the same size machine as my MX5100....with a loader rated a little higher. But that is irrelevant, because your 6' bucket load of stone isnt gonna weigh any more than my 6' bucket loaded with stone. And well below the capacity of either machine. However ballast still is a good idea because when scooping out of a pile of stone....its real easy to lift the rear of the tractor trying to "break-out" of the pile. Especially if your tires arent loaded, which I didnt see whether or not they are.
How big is your box blade? How heavy? Most of your run-of-the-mill box blades of standard duty design are gonna be somewhere around 500-700 pounds. And while that isnt enough to effectively ballast your tractor IF you were using the loader to the max....it may just more than plenty for bucket scoops 1200lbs or so at a time of gravel.
And since the box blade sticks back further than a barrel would....its less weight has more effect (leverage).
A 1000 pound barrel filled with concrete would probably be no more effective than the 600-700lb box blade. And the box blade can also be used to help spread the stone if that is the plan. (You just said move gravel so I assume you are spreading it but may be wrong).
A rotary cutter (AKA bushhog) if you have one may be your most effective ballast. As far as common implements go....they are generally near the top weight wise, if sized appropriately for your tractor. That in conjunction with how far back they are makes the most effective ballast. But due to their size and length, they arent always the most convenient.
Again, you are just moving gravel no where near the max of what your loader is rated for. But if you ever find yourself lifting logs or pallets and wanting to utilize your loader to the max....something in the form of a box or barrel that sits in close to the tractor would need to be in the 1600# range and even then I feel that may be a bit on the light side.
Hey LD1,
I am out in the country of south, central NC.
Thanks for all of the info. My box blade is a standard duty, 6’. I don’t know how heavy it is, but I’ll give it a shot.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
UNUSED FUTURE MINI EXCAVATOR HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
