2554 vs 3100
/ 2554 vs 3100 #1
JPPWNY
Rochester NY area
Cub Cadet SLT 1554 and Cub Cadet GT3100
I'm looking to buy a 2554 or a 3100 with 54" deck.
I am not a mechanical genius by any stretch, but I cringe when I look at the PTO belt twisted and contorted underneath the muffler on a 2554. To me this looks hokie and I trust the PTO belt on my SLT1554 more than the looks of the 2554 configuration.
Can anyone out there tell me if the PTO belt setup on a 2554 is reliable? bad? suceptible to problems?
I am thinking of going to the 3100 just because of this.
I know having shaft driven transmission is better than belt driven, but is having a shaft driven deck PTO that much of an advantage over belt PTO?
The 2554 looks like a heck of a tractor (except the concerns I outlined above) for the price. Just don't know if the 3100 is worth the extra $1,400 just because it has a shaft driven PTO.
Thanks for your advise.
/ 2554 vs 3100 #2
The PTO belt routing system found on the 2K series has been around for a long time. Yes, it's not as simple as a vertical shaft engine as far as PTO to deck belt routing, but that's the price you pay to have direct engine to transaxle shaft drive. FWIW, I've beat the crap out of the PTO belt on my 2544 (chunks missing) and she's still going. I would amagine avg. PTO belt life on a 2K series is over 100hrs. They take seconds to remove and replace. The idler pullies under the muffler are super deep-sheaved, so they will continue to work well with an old battered belt. If it were me & I had the need for a 54" deck, I'd go 3K series for the comfort, power everything, etc..
Joel
/ 2554 vs 3100 #3
Its what else you get in the 3100 that makes the $1400 difference go away (is it really that much of a difference or can you lower it?)
I would say the 3100 is the true value proposition in their garden tractor line.
And it gets harder to see the value proposition or it disappears when you move up to the 3200. The 3200 is a great machine but all you get is a differential lock, 2 hp and a tilt steering wheel. Its at least $1k for that difference. Besides the price of the 3200 gets close enough to the 5000 series.
However the general ease of attaching attachments, the shaft coupled quick disconnect really shines and eliminates belt wear. Of course the frame, size and comfort along with power steering and lift hydrolics all add to the value of the 3100.
Let us know which way you choose
Duc
/ 2554 vs 3100 #4
ducati, how much did you pay for your 3100? i got the 3200, (the main thing i wanted was the diff lock). but there wasnt much diff price wise between the 31 and 3200. i got out the door for right at $6k with my 3200 and 54" deck. both mowers were badass and i think the best value in HEAVY duty GT's.
/ 2554 vs 3100 #5
I guess it sounded like I was putting down the "value" aspec of the 3200 but I didnt mean it that way. There is a price difference between the 3100 & 3200
and for the most part its close to $1k.
Myself I have a 3204, which is just like the 3100
/ 2554 vs 3100 #6
I put my belt on wrong a month ago and cut the grass. I couldn't figure out why the belt would chirp when I started the pto, it usually doesn't. After cutting I realized what I did and did it right, but the belt had frayed and has some nicks and gouges. I am still using the same belt, now with 130 hours. My neighbor changed his on his 2140, at over 450 hours. As long as you put them on right, they last a long time. Yes, its a long belt and it twists and contorts but I'm telling you that they work just great. I get great power to my deck, it doesn't bog in the thickest grass and it works fantastic. I think you'll really like a 2554 if you opt that way.
/ 2554 vs 3100 #7
With a 3100 you'll get a thicker frame, power steering, (awesome) and shaft driven deck as items above the 2554. If you can justify the cost, go for it! But if not.. The PTO belt system on the 2554 is basically the same deal as on my old 682, and while the belt does take a lot of twists it works great and lasts a long time- you can even buy a Kevlar belt at TSC that last even longer than the OEM belt.
A lot of people test ride the 3000's and are sold just on the power steering. The cost of the added features of a 3000 would be nearly returned at selling time, but I don't think you would go wrong with either the 3100 or 2554.
-Fordlords-
/ 2554 vs 3100 #8
I have a 2518. The belt can be a pain if you don't put it on right. I burned one up because of that. The replacement had lasted well over 100 hours and still has plenty of life in it.
/ 2554 vs 3100
Well, best price my dealer will give me on the 3100 with 54" deck is $6,198.
Best price on 2554 is $3,800.
Big difference, bigger than I thought as I didn't realize the deck was ADDITIONAL cost on the 3100.
I know the power steering and shaft driven deck is nice, but I don't think that I can justify the price difference.
I have strong, muscular arms that can handle the steering on my SLT1554 (so I shouldn't have a problem with the 2554) and I can replace tons of PTO belts for that price differential.
If I can sell my little JD L100 before Cub's 2 yr, 0% financing offer expires at the end of July, I will go for the 2554. Thanks for all the replies.
/ 2554 vs 3100 #10
I have strong, muscular arms that can handle the steering on my SLT1554 and I can replace tons of PTO belts for that price differential.
I was wondering how you were going to get a 3100 with a deck for the money you mentioned. The difference between a 2554 and a 3100 with the 54" deck was over $2K when I bought my 2554. It wasn't worth the $$ difference to me either. If you can get a current 2554 for $3800 it's a good price. None of the dealers within 50 miles of me would move from retail.
/ 2554 vs 3100
I spend lots of money in that dealership, he normally sells the 2554 for $3999. He told me Saturday I could get the 2554 for $3800 and a Cub trimmer (promotional thing).
I do like the 2554 appearance better than the 3100, it looks like my SLT1554 (which I like) and the dashboard and all controls on the dash are exactly the same between the two.
/ 2554 vs 3100 #12
I paid retail for my 2554 and to me it was worth every penny compared to what else is available for that $. I think if you get one you won't be sorry. ;)
/ 2554 vs 3100 #13
I was in the same boat two months ago, when my local dealer sold his last 2554 I happend on a great deal in the classified ads here on this site. I got 2005 3200 GT with 60" deck and a cub 17 cu.ft. pull behind cart with 5 hours on it (used once) for $4500!! Might want to check around for a slightly used one.
/ 2554 vs 3100
Well, in casae anyone cares....
I just bought a 3100 with 54" deck.
I couldn't get over the PTO belt configuration on the 2554. I had an oooolllldddd John Deere that came with my camp when I bought it, and that JD had a very similar PTO configuration which I had tons of trouble with. I know the 2554 has a track record with the PTO setup and it certainly can't compare to the old JD, but I just had my doubts about the setup.
So, I will be much, much poorer now but I have a quality garden tractor for camp now. I just wish my wife doesn't blow a gasket when she gets home tonight!!!
My SLT1554 (which has been phenominal for me at the camp for mowing) will now become my home mower and the dealer is taking my Home Depot John Deere special in trade.
Now I need to stop reading forums because I will find something else I "NEED" to buy.....God help me.
/ 2554 vs 3100 #15
Congrats on your purchase. I am sure it will give you many years of service.
I have a 2518 with the pto belt configuration and have never had any problems other than the fact I didn't put the belt on right once and shredded it. A $32 mistake. I get it right everytime now!
Volvo VNM (A63688)
Volvo VNM (A63688)
MERRITT ALUMINUM HEADACHE RACK (A64277)
MERRITT ALUMINUM...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
John Deere 4044M (A60462)
John Deere 4044M...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
3012SFL (A61567)
3012SFL (A61567)
