2550 Oil Consumption Continues
   / 2550 Oil Consumption Continues #1
Dascro
SW Pennsylvania
Kubota B7610, Cub Cadet 1450
I know that oil consumption in this model CC has been discussed in a number of threads over the past couple of years. I perused several of them and noted that most oil consumption issues seem to clear up after some time. Except mine!
I seem to be loosing about 5 oz. of oil each time I mow. No leaks and no indications the engine is burning it. I am using Mobil 1 10W40. I have about 45 hours on the tractor so far.
Anyone else experiencing this same problem? Everything else seems fine. Runs strong (still a little hot, but par for the course for these I guess), mows good, etc.
Thanks,
Dave
   / 2550 Oil Consumption Continues #2
I think you will find that Mobil 1 10w40 is a friction modified oil . If it is , it will prevent the rings from "bedding" in , and it will use oil . Ask your supplier or Google it to find out for sure . You should run a non friction modified oil while the engine is breaking in . After a few hundred hours it will be fine to use friction modified oils again .
   / 2550 Oil Consumption Continues #3
I totally agree. Use a good brand of dinosaur oil for the first 100 hours or so. I think Kohler recommends that too.
-Fordlords-
Thanks for the replies.
Nothing in the Owner's manual about engine break-in lasting up to 100 hours. It does mention "ship away" oil and changing it after 25 hours. Which I did. Figured they defined engine break-in as the first 25 hours. Consequently, I started using Mobil 1 after 25 hours.
I'm familiar with engine break-in, and fully agree that the first several hours of operation are critical to achieve proper ring seating. I believe during that period it is also important to vary RPM's, and give the engine several "heat cycles". All of which I did. But I never heard of a 100 hour break-in period for a small engine, and I have owned a few new ones and rebuilt a few over the years. All were taken through the same break-in as this one on the 2550 with no problems.
Not arguing with anyone. That's not my intent. Just surprised to hear that break-in can last up to 100 hours on these small engines. But perhaps that's correct as it is using oil some how. Never thought it could be break-in issues at the 50 hour mark.
Dave,
   / 2550 Oil Consumption Continues #5
How long is it taking to loose 5oz? (how long per mowing) That is quite a bit. You should be able to see & smell it at that quantity I'd think. Is it oily need the carb throat? Maybe oil is being blown through the breather tube and into the carb? I switched mine to Shell Rotella-T 5w40 (synthetic blend) at about ~30hrs. No measurable consumption. Oil looks clean forever.
Joel
I loose the oil over two mowings (which equals about 5 hours total). I add oil to the "Full" mark on the dipstick and then after about two mowings the oil level is about halfway between the "Full" and "Low" markings on the dipstick. Seems like a lot to me.
I'll have to check around the carburetor. No oil smell at all though.
Thanks,
Dave
   / 2550 Oil Consumption Continues #7
Switch back to dino oil for awhile and see what happens. It's cheaper too.
   / 2550 Oil Consumption Continues #8
I do not believe the Mobil 1 is your problem. My guess would be a valve guide. Kohler Commands a few years ago, did have a oil usage problem but I can not think what the trouble was. Might have been a head gasket.
   / 2550 Oil Consumption Continues #9
Have to agree with dqdave1 that your problem probably isn't a Mobil 1 or break-in issue. I started using Mobil 1 10W-30 about the same time you went with the 10W-40 and my 2542 doesn't use any oil. The only difference is that I changed the oil, using dino oil, at about the 10 hour mark because I didn't like the idea of metal particles from a new engine being in there until the 25 hour mark. It now has 121 hours on it. I never saw any oil usage after going to Mobil 1.
Thanks.
Yeah, my thinking is along the lines of the last two posts. The break-in period is long over, no doubt. And there is a lot of conclusive scientific and real-world data (statistically significant in both cases) that allays any concerns associated with synthetic lubricants causing oil use (when used in sound engines).
Any ideas on how or where I could find info about the Kohler Command oil usage problems mentioned above?
All the input and information is appreciated.
Dave
2012 Dutchmen Voltage V3950 42FT 5th Wheel Tri-Axle Toy Hauler Travel Trailer (A51694)
2012 Dutchmen...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
20 ft. Shipping...
