Tractor News 2545 Shuttle Cab
/ 2545 Shuttle Cab #1
Budlight592
Tarkington Prairie, Texas
2017 LS XR4155HC
Has anyone seen this new model yet? Anyone test drove or have any information on this model. Looks well equipped and specs out well.
/ 2545 Shuttle Cab #2
One thing I noticed is on the loader they saved pennies by not providing a 4 Link at the bucket for good articulation.
Seems like a nice mid size CUT.
/ 2545 Shuttle Cab
Are you sure because the pictures that I have seen it shows 4 link at the bucket. Have you seen it in person?
/ 2545 Shuttle Cab #4
No
Maybe I was looking at Pictures of a different Tractor, If 4 link, that's a plus.
Can you post photo's?
/ 2545 Shuttle Cab #5
From what I can tell, it is essentially the same as the prior 2540, but with an up rated engine spec. The 2538 HST and 2540 are great midsize CUTs, so I would expect additional greatness from the 2545.
They just updated the brochure and changed the number and HP rating, but everything else is based on the 2540, so you might check some of the reviews for that tractor on here. (Similar capability feedback from a 2538 may be applicable as well, then the 40 and 45 have a few more features standard, (suspension seat, slightly more powerful loader, etc...)
2545 4WD Shuttle | Mahindra
/ 2545 Shuttle Cab #6
The biggest plus to me is shuttle shift in that hp but a small framed tractor... it will be nice for heavier 6ft mowing in tight spaces... but I like the open much better than the cab.. just more practical.. its nothing more than a 2538 frame.. the shuttle is not quite as smooth as other but is common with TYM builds. other than that and a few cheapy plastics it seems like its going to be a nice model and have its place in the market... imho I couldn't justify it over a 3540 or 4540 other than NEEDING that smallest frame possible
/ 2545 Shuttle Cab #7
Anyone know if the 2545 Cab is available or what the pricing is?
Thanks
/ 2545 Shuttle Cab #8
Thanks
Only if you can get a loader tossed in at the base asking price on the website would it be a great price.
/ 2545 Shuttle Cab #10
I am new to this forum and am looking at the 2545 shuttle cab. Does anyone have a opinion?
/ 2545 Shuttle Cab #11
The Shuttle on my Max28 does not make me wish for an HST 80% of the time. Shifts Nice and I can chug chug at low RPM.
I think the 2545 is a great size power and capacity tractor for small and medium work. Big enough to handle round bales if your careful and just stacking one high. Ought to handle an 8' snow plow, and 6' cutter. Good size for the woods.
/ 2545 Shuttle Cab #12
Thanks for the reply. My thoughts exactly on this model. I am interested in the test drive once my dealer gets one in to see what low first is like. I might one day do tiller work and like going slow enough for the tiller. I don't do much FEL work so clutch is not a problem and if I spring a leak in the hydraulics I can still drive back to the shop to fix.
/ 2545 Shuttle Cab #13
go with the 35 series
/ 2545 Shuttle Cab #14
Interesting you suggest the 35 series. My local dealer said they had issues with both the hydrostatic and shuttle transmission versions. He said they are not going to stock the 35 series anymore.
/ 2545 Shuttle Cab #15
I have the 2540 the same as the 2545 just the newer 2545 has 44 hp compared to 40 hp and 39 hp at the pto compared to 35 at the pto. My dealer told me it was the exact tractor except for these few differences. My 2540 is already a strong little tractor so more power out of the same design is great. the 2540 has a very nice turning radius compared to some of the other models it is a little shorter in length. I have mine on a little over 2.5 acres and it works for me. I was going to get the 2538 but decided on the bigger of the two and glad I did. I have not been able to find many owners of this size tractor so I can't give any other insight other than I have no complaints I only have 120 hours on it. I don't know if this helps but any other question I'll be happy to answer.
/ 2545 Shuttle Cab #16
The 2645 that I just ordered had a 4 link at bucket. One strout 45 horse tractor.
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
