2544 GT Brakes Question
   / 2544 GT Brakes Question #1
tincup703
VA
CubCadet 2544
OK so what's the secret to get the brakes working on my tractor?
Even on flat ground the brakes wont stop the tractor unless you quickly take your foot off the gas pedal and let the tractor "compression" brake itself first (which about jerks you off the seat).
I've checked all the pedal linkages and nothing is binding and appears to be working properly. Anyone else seen this?
tc
   / 2544 GT Brakes Question #2
Try adjusting them according to the manual and see if you can get them to work. I had to do that when I got to about 10 hours, but haven't had to touch them again in the 45 hours since then.
   / 2544 GT Brakes Question #3
tincup703 said:
..Even on flat ground the brakes wont stop the tractor unless you quickly take your foot off the gas pedal and let the tractor "compression" brake itself first (which about jerks you off the seat).
I'm not sure I follow... So when coasting, on a hill, or trying to park, you hit the brake pedal and nothing happens (it doesn't hold)? The brake shouldn't hold against force from the hydro. You need to be completely off of the forward/reverse pedal before you hit the brake pedal. Honestly I don't think I've ever used the brake on my 2544 other than mashing it for engine starting. The way the pedal is placed, I think it was only intended as a parking brake.
Joel
   / 2544 GT Brakes Question #4
I'm with you JT. I have a 2542 and my tractor stops before I can even think about using the brake once I get off the go pedaL
   / 2544 GT Brakes Question #5
Mine doesn't stop immediately, sometimes I have to tap the opposite direction to get it to quit moving quickly. I guess I need to adjust the hydro controls huh?
90018 (A48082)
90018 (A48082)
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
