2542 cut
/ 2542 cut #1
moe1942
Louisiana
GT2542
Does anyone else experience a lousy cut with this tractor? seems mine leaves a small uncut strip. I have checked everything numerous times and still have the problem. The gap between the blades is much smaller than the strip of grass.
/ 2542 cut #2
I have the 2544. I have the same problem too (strip on the right), but only if I set the cut too low or if mud or grass has built up on that side of the deck. I keep it clean underneath and keep my setting a little higher.
/ 2542 cut #3
check the guide wheels they should just be touching the grass when you mow. also make sure you don't have a bent blade and the deck is a click nose down out of level.
/ 2542 cut
Thanks for the replies. I think someone on MTF might have nailed the problem. I left the mulcher plug in after doing the leaves last fall. Think grass buildup may be causing the problem. Will take it out and cut the grass and see if it corrects the problem.
Rann007 what you said sort of confirms that suspicion...
/ 2542 cut #5
Yeah, keep that deck shiny underneath if you can. It's the #1 cause of rust and wear.
John Deere Z997R (A60462)
John Deere Z997R...
2000 Malibu (A62613)
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
John Deere 4044R (A62177)
John Deere 4044R...
