2542 cut
/ 2542 cut #1
moe1942
Louisiana
GT2542
Does anyone else experience a lousy cut with this tractor? seems mine leaves a small uncut strip. I have checked everything numerous times and still have the problem. The gap between the blades is much smaller than the strip of grass.
/ 2542 cut #2
I have the 2544. I have the same problem too (strip on the right), but only if I set the cut too low or if mud or grass has built up on that side of the deck. I keep it clean underneath and keep my setting a little higher.
/ 2542 cut #3
check the guide wheels they should just be touching the grass when you mow. also make sure you don't have a bent blade and the deck is a click nose down out of level.
/ 2542 cut
Thanks for the replies. I think someone on MTF might have nailed the problem. I left the mulcher plug in after doing the leaves last fall. Think grass buildup may be causing the problem. Will take it out and cut the grass and see if it corrects the problem.
Rann007 what you said sort of confirms that suspicion...
/ 2542 cut #5
Yeah, keep that deck shiny underneath if you can. It's the #1 cause of rust and wear.
2016 Ram 5500 Flat Bed (A63688)
2016 Ram 5500 Flat...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
