2542 cut
   / 2542 cut #1
moe1942
Louisiana
GT2542
Does anyone else experience a lousy cut with this tractor? seems mine leaves a small uncut strip. I have checked everything numerous times and still have the problem. The gap between the blades is much smaller than the strip of grass.
   / 2542 cut #2
I have the 2544. I have the same problem too (strip on the right), but only if I set the cut too low or if mud or grass has built up on that side of the deck. I keep it clean underneath and keep my setting a little higher.
   / 2542 cut #3
check the guide wheels they should just be touching the grass when you mow. also make sure you don't have a bent blade and the deck is a click nose down out of level.
   / 2542 cut
Thanks for the replies. I think someone on MTF might have nailed the problem. I left the mulcher plug in after doing the leaves last fall. Think grass buildup may be causing the problem. Will take it out and cut the grass and see if it corrects the problem.
Rann007 what you said sort of confirms that suspicion...
   / 2542 cut #5
Yeah, keep that deck shiny underneath if you can. It's the #1 cause of rust and wear.
1273 (A50490)
1273 (A50490)
2016 Bobcat E85 Midi Excavator (A50322)
2016 Bobcat E85...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2012 Ram 4500 Versalift EL29N 29FT Bucket Truck (A50323)
2012 Ram 4500...
Toro Mower (A50324)
Toro Mower (A50324)
