2538 transmission/hydraulic oil capacity and sight glass question?
   / 2538 transmission/hydraulic oil capacity and sight glass question? #1
mike35549
Walker Co. Alabama
Mahindra 2538 with FEL
Had a little problem today pushing some brush punched a hole in the rubber hose that connects the transmission to the pump. No big deal went got one changed it out. Caught the fluid that came out in a bucket what seemed like 4-5 gallons went and got 4 more gallons put what I caught plus the 4 gallons which should have been 8-9 gallons but still can't see any fluid in site glass even thought maybe I just couldn't see it looked with a light The book says 8.5 gallons for you guys that have changed yours is 8.5 gallons correct. And if so how much did it take to get from bottom of site glass to full. Also is the site glass the only way to check the level. Was hoping there was a dipstick I don't want to over fill it.
   / 2538 transmission/hydraulic oil capacity and sight glass question? #2
   / 2538 transmission/hydraulic oil capacity and sight glass question? #3
yup, JD has the oil dye. They might have to order it for you though. Well worth the $4.
   / 2538 transmission/hydraulic oil capacity and sight glass question? #4
JD oil dye...... part number MT3668......... highly recommended. I used half a bottle.
Talk to the dealer and there is no other way to check level on the 2538 other than the sight glass. Turns out it was over full. Drained some out while someone watched sight glass with a flashlight now it is right on the red dot. Live and learn I guess.
New Long Forks (A53002)
New Long Forks...
2014 Caterpillar 289D High Flow Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
