2538 rear tire lug nut issue
   / 2538 rear tire lug nut issue #1
CDBUG
State O' Maine
Mahindra 2538
Anyone else have these lug nuts keep loosening ....I use this tractor slow and easy and on the rear 'left side only' ..I have to constantly tighten them
   / 2538 rear tire lug nut issue #2
Sorry, but I haven't had to tighten mine in 8 years.
Have you removed the wheel to see if there is something between the hub and where the wheel marries up? Might be causing your problem. Do you have Ag tires or the industrial tires?
Try putting some Lock-tite on the lugs and nuts.
AG tires....Checked and tightened all with some blue locktite .....that one nut and the opposing one still loosened up after a couple hours grappling firewood. .....puzzling
   / 2538 rear tire lug nut issue #4
Obviously, something is causing them to loosen. Check the threads in the nuts and the lugs. Maybe they're damaged, or stripped or something like that. If the issue(s) are limited to just those specific lugs & nuts, then I'd focus there. If random lug nuts loosen that would likely be different problem.
Tough to say exactly what's wrong, but I'd eliminate thread issues before moving on to other potential problems.
Thanks duffer for the reply.. It is ponderous! [threads and all look fine] I today brushed and cleaned the 'B Jesus' out of em again with brake cleaner.. waited a bit..'rag cleaned' and then used the 'red locktight'.....fingers crossed for the next run.. tomorrow or next.
   / 2538 rear tire lug nut issue #6
Beg, borrow rent or steal a torque wrench suitable for those lugnuts, tighten them, torque them and then drive it around a couple hours. Re-check the torque and see if any have loosened.
David from jax
   / 2538 rear tire lug nut issue #7
I wonder if these lug nut retainers would help:
Or maybe the alltiresupply people could recommend something.
David from jax
Of course done and done again
   / 2538 rear tire lug nut issue #10
I tightened the lug nuts on my 2638 about 80 hours into owning it with a 4' cheater bar and have yet to find one loose 4 years and 700 hours later.
2014 MACK GU713 WINCH TRUCK (A53843)
2014 MACK GU713...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
UNUSED Double Stall Portable Bathroom (A53117)
UNUSED Double...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
2023 Yamaha Wave Runner Deluxe with S/A Aluminum Trailer (A51694)
2023 Yamaha Wave...
