2538 oil change capacity
   / 2538 oil change capacity #1
mike35549
Walker Co. Alabama
Mahindra 2538 with FEL
Changed the oil and filter in my 2538 today The book says capacity is 5 liters, however when I changed it today it took 6 liters to get it just below the full mark. Maybe the 5 liters in book is without filter change. How much oil has everyone else been having to use when changing oil in there 2538.
   / 2538 oil change capacity #2
Mine took 7 1/4 quarts w/ mahindra filter. Reading is a tad below the full mark after start-up and settle. Oil drained from both plugs.
   / 2538 oil change capacity #3
Mine took about 7 quarts. 6 certainly isn't enough, esp with filter change.
   / 2538 oil change capacity #4
My 1538 took 8 quarts oil with a new Mahindra oil filter to read full after startup and settle. Same engine as 2538 but maybe oil pan is different resulting in slightly different capacity? Make sure you drain both plugs.
I did drain both plugs, and didn't much drain out of one side but the little that was in there was quite a bit dirtier than what came out of the other side.
   / 2538 oil change capacity #6
Yes the first one you drain will always have more oil come out. The second one will only drain what remains on that side of the driveshaft hump. Hope that makes sense.
   / 2538 oil change capacity #7
Does anyone have part numbers for the filters? To do oil,fuel and air cleaner?
   / 2538 oil change capacity #8
Courtesy of another poster (sorry, I don't remember his name) here are Wix filter numbers for the 2538/2638.
  • Oil filter: 51324
  • Air filters: 46489 & 46490
  • Fuel (1st): 33993
  • Hydraulic: 51586 (Same # for Duramax brand)
  • Fuel filter with water accumulator and sensor housing: Bosch: # F002 H22 025
I get most of mine from ebay and Amazon. Doing my 1500 hour service tomorrow. All fluids, filters, grease, inspection, etc.
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
John Deere 724J (A47384)
John Deere 724J...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
