Loader 2538 Lift Capacity
   / 2538 Lift Capacity #1
tracydj
Bourbon, MO
Mahindra 2538
I was power washing vegetable oil out of an IBC tote this morning which gave me a great opportunity to test lift capacity. Mahindra's published loader capacity is 1634 lbs. I estimate I had 170 gallons (1417 lbs) in the IBC tote (100 lbs) and the machine had no issues lifting it. It would not lift at 195 gallons. (1626 lbs + 100 lbs IBC) I assumed that my forks would be a little lighter than the bucket which would have increased the capacity but that was not the case.
   / 2538 Lift Capacity #2
Good info! Have you or the dealer verified hydraulic PSI?
I have not verified hydraulic psi. I would assume that it would be a test the dealer would have performed on the pre delivery checklist. Knowing my dealer, it has never been verified.
   / 2538 Lift Capacity #4
Ok perfect. A good "factory" test result for the archives. Thx for posting
   / 2538 Lift Capacity #5
The weight Mahindra gives is measured at the pins to maximum height. You are lifting 1517 lbs plus the weight of your forks (usually about 150 lbs) and the weight is way in front of the pins. So your loader is probably working right. You were able to lift about 1667lbs.
   / 2538 Lift Capacity #6
Its working correctly.. remember loaders lift are measured at the pins.. the further your distribute weight forward of those pins the capacity will drop.. with the bucket your able to scope and curl back putting the weight almost on top of the measured poundage
   / 2538 Lift Capacity #7
Yep. Lifting that weight out on the forks would mean his loader was actually lifting more than the rated capacity at the pins. It's working fine.
   / 2538 Lift Capacity #8
When using those totes I tend to move them full. Otherwise there is too much slopping side to side and front to back. I had one slide off the front even though I had it somewhat tilted back.
   / 2538 Lift Capacity #9
Thanks for the info tracydj. I moved a full tote recently for the first time. It was full to the cap so 275 gallons. I had my 7' finish mower as a counter weight at the back. It did fine but there was a lot of bounce in the loader. I don't think I'd want to lift much more nor would I want to lift it to height.
   / 2538 Lift Capacity #10
The bad thing about my L39's FEL is that it stays on the tractor. The good thing is there is virtually no bounce and very little flex compared to the typical removable ag. style loader. I never tried lifting a 275 Gallon tote. For sure, I would not try full height.
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
