Price Check 2520
   / 2520 #1
shafshak
Western PA
1952 Ferguson TO30
2008 2520 100 hours, 60 inch mmm,with loader, tires filled, price $14500.00 good or bad ??????????
   / 2520 #3
I would say that price is "in line" with what they are going for.
Is it a dealer or a private seller?
Greg
   / 2520
it is a private seller
   / 2520 #5
At that price it may be worth your time to look at new.
Yes, the price will be more but, 0% financing and a warranty has value as well.
I would hope you wouldn't need the warranty, after all, it'a Deere.:thumbsup:
Once you go Green your pride goes through the roof.!!
The price is right on the used tractor so long as it checks out good.
Best wishes.
   / 2520 #6
That is a good price if there are no problems with the machine.
   / 2520 #7
Might depend where you are located.
When I was looking for new or used in 2007 there were much better deals on both new and used in the heartland , but by the time ya paid for transporting it, it wasn't worth it.
Some might consider 100 hours hardly broken in yet.
(Course, that's exactly how many hours I have on mine) :)
   / 2520 #8
I was looking at the 2305 and 2320 awhile back. I ended up surfing the net and found lots of stories where the rear PTO blew out with minimal use. Does anyone know if issue has been addressed? The one thread I read said the guy took it apart himself and found the housing was made of thin aluminum. I think I'll stick with my JD 1070 for now...
   / 2520 #9
The OP was asking about a 2520,which in fact has a much beefier rear end.:) As for the "weakness" of the 2305 and 2320,who knows as to the real reason why they would fail.
Any size machine will fail if pushed well beyond their spec max limits.
Greg
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
1998 Ford F800 2,000 Gallon Water Truck (A49461)
1998 Ford F800...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
