2520 w/log splitter cycle times?
   / 2520 w/log splitter cycle times? #1
prosperity
Platinum Member
North Central Pennsylvania
JD 2520
Even though winter is about over, I am thinking ahead for next year....
Now that I am burning wood for heat, I'm thinking of buying a tri-axle load of wood instead of buying it cut & split.
I've done an exhaustive search on the forum, and it seems to come down to hydraulic flow being the main factor when using a 3PH splitter.
So, looking at the 2520 specs, the pump puts out 10+ GPM, but it also shows an implement flow of 5GPM.
As specs don't mean much to me on paper, I was looking for some real world information on the cycle times of a splitter on the 2520. I don't want to make the mistake of spending that kind of money on a 3PH splitter only to find that I can't stand the slow cycle times.
Anyone with a splitter on a 2520?
   / 2520 w/log splitter cycle times? #2
Cycle times will depend on both flow and cylinder size. I made a towable one last year powered from the tractor hydraulics. The splitter I used as a donor had a 4" bore cylinder on it. My times are slower than some, but I can split larger logs. For me the cost of the parts ($50.00) and what I save in physical labor to split logs was well worth the cycle time being slow.
   / 2520 w/log splitter cycle times? #3
PM user "gunmaker", he has a Speeco (from TSC) on the 2520.
2014 Electric Cart (A53424)
2014 Electric Cart...
Wooden Rack Hay Wagon (A50775)
Wooden Rack Hay...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2020 KUBOTA X1100C RTV (A51406)
2020 KUBOTA X1100C...
