2520 W/62d deck- deck is still falling out
   / 2520 W/62d deck- deck is still falling out #31
47Chevy, this is really a weird problem. I don't think anyone else on this forum as had such a problem have they? There has got to be something else wrong with your hardware or setup. Is the front mount for the deck adjusted properly? Perhaps if that is incorrect it could cause some weird loading on the J pins that caused them to work loose. Or maybe you have the "too long a drive shaft" problem that I saw someone else had on some JD machine with 62D deck. Does you deck lift properly and evenly? That might cause the deck not to lift properly and cause some of these pin problems. I don't know what it might be but I think I'd look at all other prossible problems. You have something more going on then just bad luck. Another thought, is your deck vibrating really bad? Perhaps it is severely out of balance for some reason? I'm just taking shots in the dark but I cannot imagine why you are having the problems that you are. I hope you figure this out.
Hose Reel (A53424)
Hose Reel (A53424)
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI SGB20...
Club Car Carryall 1500 Diesel Utility Cart (A55787)
Club Car Carryall...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
