2520 Transmission Whine
   / 2520 Transmission Whine #1
revitupfaster
Southern Ontario Canada
JD X495 & JD2520
I just got my new 2520, and I think I read somewhere that the Hydrostatic Transmission in the 20 series models have a pretty good whine to them. I also have an X495, but the 2520 is a far more noticeable (louder) whining noise. Almost sounds like it's straining.
Is this normal?
Does it get any quieter as it breaks in, or is this just the way they
operate?
REV
   / 2520 Transmission Whine #2
I noticed in your other thread, you said you are mowing in high range. It seems to make more noise in high range than low, but it's fairly noisy in both. Mine has 164 hours on it and still makes quite a bit of noise. I believe it is normal.
By the way, congrats on the new machine, I know you'll be happy with it.
   / 2520 Transmission Whine #3
Normal. High range is usually louder as well.
Thanks boys, I thought I had read somewhere that it was normal , just wanted to confirm.
REV
   / 2520 Transmission Whine #5
Hi is really loud, and sounds like it is straining. I rarely use Hi for anything anyway. Its not really made to do any work in hi.
Low doesn't make alot of noise, or I am just really used to it and don't notice it anymore. :thumbsup:
   / 2520 Transmission Whine #6
Are you running HyGard Standard or LowVisc HyGard ?
Big difference in transmission pump noise between these
two different viscosities.
   / 2520 Transmission Whine #7
...but the 2520 is a far more noticeable (louder) whining noise. Almost sounds like it's straining.
Is this normal?
Well, after 10 years on TBN, I've found most HST owner operators are whiners (unlike us Strong Silent Manly Gear Men)
   / 2520 Transmission Whine #8
Gotta tip my hat to you on that come back RJ. ;)
   / 2520 Transmission Whine #10
Even a long time hydro guy can appreciate that....
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2013John Deere 244J (A47477)
2013John Deere...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
