2520 tractor hydraulic leak
   / 2520 tractor hydraulic leak
Thanks Guys.
Thanks Gizmo I cound not find that in JD parts myself, but that sure looks like item number 3 :thumbsup:.
I think there is a JD service manual CD in my near future.
Doesn't look that difficult to replace, but not sure about how easy to get at the transmission end of things.
   / 2520 tractor hydraulic leak #12
Thanks Guys.
For what these tractors cost, a service manual was the first item I bought. Did the same for our old JD 650. I figure it pretty much pays for itself the first time using it especially after many years go by and and issue shows up and no one has a clue what you are talking about.
   / 2520 tractor hydraulic leak #13
"For what these tractors cost, a service manual was the first item I bought. "
I do the same thing...then, pray that Murphy's law holds up so that I won't have to use it...
   / 2520 tractor hydraulic leak #14
My new 2520 has been running ok for 8 days. Today while backing up I thought I was seeing smoke and my heart sank. I aslo noticed wet leaves and realized I must be leaking something. I immediately stopped and saw what I beleived was hydraulic fluid dripping from one of the power steering hoses. I started the tractor and thought if I turned the steering I would be able to identify which hose was the culprit. To my surprise it was leaking not from either hose, but from the bottom of this unit I have yet to identify.
There is a spray coming out of a pin hole leak on the pipe very close to where it is welded to some sort of round metal cover with three screws that I can feel (with the tractor off). I imagine the smoke was the fluid somehow hitting the hot engine or exhaust ?
My dealer is closed for the day so I will call in the AM, but I would like to be able to intelligently tell him what the problem is.
That's the high pressure line from the pump and it's a factory defect. I bought a new 2720 and after 25 hours I had the misfortune of having mine blowing fluid all over the place. I called my dealer and had him check it out , At first they didn't want to replace it so I told him to be ready to take the tractor back and refund me my money. The leak was a split in the high pressure tubing which is rolled and electronically welded. some how they blew the welding job, However the real problem is replacing the line. Its a major pain in the butt to get the old one out and get the new one back in place. Please have your dealer do the job and save yourself some grief.
PS My leak was on the other end of that same line where it goes into the SCV . What a pain!
Wooden thanks. Yes made all the arrangements to drop it off at the dealer tomorrow.
   / 2520 tractor hydraulic leak #16
That was the same exact line that blew out on mine with 25-30 hours on it, but mine blew out under the seat. Looks like they might have a problem with this line..... The mechanic showed me where it went and it bolted in the same exact place yours does! The dealer came and picked mine up and repaired it and brought it back.....
   / 2520 tractor hydraulic leak #17
Would you guys post your vin numbers so the rest of us can see if we have units in that range?
   / 2520 tractor hydraulic leak #18
Where is the vin number located at? Seems like its random though....
Well I can't give you a vin at this moment as the tractor is at the dealler being repaired.
However I did get a call this morning from the dealer telling me they have replaced the bad line and my tractor is ready.
My failure was on the metal linne up againist the welded area on the hydro pump.
The dealer said he hasn't seen that before. I responded that I have talked to two other owners one with a 2520 and another with the 2720 and they both experienced the same hydro line failure.
Hoping the get the tractor back Saturday, and be back in the saddle :thumbsup:
   / 2520 tractor hydraulic leak #20
"Oh, we've never heard of a problem like that before"
I wish I had money for every time I've heard that before ;)
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
CATERPILLAR D8T CRAWLER DOZER (A52707)
CATERPILLAR D8T...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2016 Club Car Precedent Electric Golf Cart (A53424)
2016 Club Car...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
