2520 - Running Out Of Power
   / 2520 - Running Out Of Power #1
megaboz
Platinum Member
Fairmont, WV
'17 2032r (soon)
I've noticed that when backing up steep grades running the mower deck I lose power, too me big power even when going slow. Running at 2700 RPMs, I have seen the RPMs drop to 1200 when running the belly mower.
I've tried going slow, and even then I lose 500 to 700 RPMs.
This is all in LOW range, not Hi.
Anyone else have similar experiences?
   / 2520 - Running Out Of Power #2
Isn't reverse a higher gear ratio in these tractors?
   / 2520 - Running Out Of Power #3
I was working mine a week or two ago and with loader on, 72" deck mowing and in low range I could drop it down 200-500rpm. My hill is a 10% or greater hill. You need to take yours in and get it checked. I was pulling my trailer yesterday with a couple yards of dirt and I didn't go over 1300rpm up small hills.
   / 2520 - Running Out Of Power #4
Is your tractor new? I have a 2320 and it was only 11 HP. We put it on the dino for an hour. Power came up to 18 where it should be. They need to be worked hard to break 'em in.
   / 2520 - Running Out Of Power #5
megaboz,
You didn't have the reverse pedal to the floor did you?
I have tried everything, reverse to the floor shuts the tractor off, I've tried variable speeds, it just loses a lot of power no matter what. If I creep about one MPH it does ok, not great but ok.
Sadly, now it is kinda of whining (making a high pitch noise in a forward gear now) kind of like it is struggling. I'm beginning to think there is something wrong with the with the whole hydro static.
Several times today I noticed a some power loss in forward gear in low range when climbing hills.
With 7 hours on it, I am starting to worry.
   / 2520 - Running Out Of Power #7
I don't mow on very steep grades, but I've never had a loss of power like you describe while running the MMM. I have 60 hours on my 2520.
   / 2520 - Running Out Of Power #10
Hi,
I would check the fluid level. Is there fluid in the sight glass when on level ground? Did you pull the dipstick and verify the level? (it's below the range selector lever, you'll need a rod to hook the dipstick and pull it out.)
Hydrostats make noise if the pump picks up air and they don't have any power at that point either. (The guy next door found this out on his Cub lawn tractor last year)
If your backing up a hill and the fluid level is low you could be uncovering the pickup for the pump which I believe is to the rear on the 2x20 series. (not 100% on that though)
Tom
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
