Snow 2520 leaking hydraulic fluid
   / 2520 leaking hydraulic fluid #1
Jack Murdock
Stephentown NY
John Deere 2032R
I am looking for a technical manual for a 2520 to see if replacing this leaking seal on my mid-mount PTO is a big deal and to try and figure out what the part number is.
Thanks in advance for any help you may offer
Jack
   / 2520 leaking hydraulic fluid #2
Which 2520(rowcrop or CUT)? If a CUT then I think mid pto seal is part # R91131 which is $4.20 from JD
I just left the local JD dealer and he gave me seal # M800600 / and sleeve CHI4967 but didn't have either in stock.
   / 2520 leaking hydraulic fluid #7
It looks like a pretty big deal to change. According to the tech manual it has to be disassembled from the inside after removing and splitting the transmission.
   / 2520 leaking hydraulic fluid #8
Are those bolts around the pto a removable plate? If so it might not be to hard.
I had to change the pto clutch on my 2520. If I remember correctly it was over 20 hours in labor just to disassemble to get to the part. Hope you don’t have to.
I will look at mine and the manual when I get a chance and see if I can offer any insight.
I just changed a leaking seal in my front mount snowblower. Took 2-3 hours and I was surprised how much I had to disassemble to get to it. Note to self, don’t accidentally snowblow a garbage bag full of empty cans.
   / 2520 leaking hydraulic fluid #9
It looks like just the cover plate and the seal
It looks like the cover plate and the seal hopefully not a big deal. I ordered the seal and spacers and my neighbor will do it this weekend and hopefully will go well.
Thanks for everyone's time.
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
JMR Safety Basket (A53316)
JMR Safety Basket...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
Portable Restroom (A54865)
Portable Restroom...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2006 FORD F-250(INOPERABLE) (A55745)
2006 FORD...
