2520 in the Nor'easter
   / 2520 in the Nor'easter #1
gunmaker
nw nj
jd 1025r / x750
What a blast! We got 12+ inches of snow in this storm, and I got to play in the snow until I ran out of driveways to plow. This was the first real test of the 2520 with the Meyers 6ft blade attached. I wasn't sure if adapting the JD Quick-hitch to the Meyers blade was maybe stretching things abit, but it worked better than I had hoped.
   / 2520 in the Nor'easter #2
Do you feel the front blade is a lot better than just using the FEL for snow? We had about 10" of a combination of snow and ice over the last couple days, and I thought the FEL worked pretty well.
If you dont' mind me asking, about how much for a front blade and all the attaching hardware?
   / 2520 in the Nor'easter #3
Looks good ! nice job - I cant find your pictures when you first set up the myers plow - I think that will help inquiring minds :)
I thought that a front blade would be faster than the fel in my situation, so I fabricated an adapter, which when welded to the rear pivot frame of a Meyers plow, allowed me to attach the plow to the JD factory Quick-hitch. It operates using the factory hydraulics.
I still use the fel when I have to move large piles, but the front blade gives me more flexability (gravel lane, paved driveway, grass parking) when plowing.
Mike 5252- the plow blade was a gimme, found on a friends farm. The steel and paint was about $100 bucks, because I bought new 1/4" plate steel, and 5/8" rod for this project. Craig
   / 2520 in the Nor'easter #6
A Ballast weight would make that Beast push 3 times as much. Its amazing what some weight on the azz end does. :cool:
   / 2520 in the Nor'easter #7
You wouldn't happen to have a picture of the blade at it's maximum height would you? I might upgrade and I would love for the blade to lift higher than my 2210.
I can get the blade 14-15 inches off the ground.
   / 2520 in the Nor'easter #9
Wow I'll bet you can stack the snow real good with that.
Wheel Loader Broom (A50775)
Wheel Loader Broom...
John Deere Turf Gator (RUNS) (A50775)
John Deere Turf...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
24" Terrell Gearbox Platform Ditch Pump (A53314)
24" Terrell...
19015 (A55788)
19015 (A55788)
